Results 1 to 12 of 12
Thread: Help with new pool
    Jun 2016
    Coatesville, PA
    12
    Help with new pool
    Hello all, this is my first pool and I need help. We have a 25ft by 52in chlorine pool which I believe is about 15000 gallons. It is in direct sun for the majority of the day. 1.5hp pump and sand filter.
    I had been following my father in laws instructions but they are not helpful. Our numbers are horrible and I think we are getting some kind of black algae stuck to the vinyl liner is spots.
    I just brought the TF-100 kit and ran some tests. Even after dumping a load of chlorine in we have none in the pool. I think the sun bakes it out. We have been using pool store chlorine, some Algecide and clarifier. But I stopped using everything once I realized we weren't making a difference. We still have about 10 gal of chlorine.
    CH = pink or 325ppm
    TA = 200
    CYA = n/a, clear water.
    I'm not the kind of person to just start doing things for fear I'll make it worse. So any suggestions would be appreciated. If you need any more info let me know.
    25'x52" 15,000Gal Above Ground Chlorine
    1.5HP HydroTools Pump
    Sand Filter
    TF-100 Test Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,648
    Re: Help with new pool
    Lets' get your PH in the mid 7 range, add enough CYa to raise it to 30, and follow the SLAM process for that level. Welcome!
    Jun 2016
    Coatesville, PA
    12
    Thank you. Pardon my lack of pool knowledge....
    What is CYA and where do I get it?
    Sand Filter
    TF-100 Test Kit
    Apr 2010
    East Texas
    9,648
    It is also called Conditioner. Comes in 4lb. granular jugs at Wally World.
    Jun 2016
    Coatesville, PA
    12
    Ok sweet, thank you. Should I stock up? Here is what the previous owner left us... Should we just trash it and start fresh? uploadfromtaptalk1466964203227.jpg
    Sand Filter
    TF-100 Test Kit
    Apr 2010
    East Texas
    9,648
    That Stabilizer and Conditoner is your CYA. Only thing tere to pitch is the clarifier. I can't make out what the green label short jug is.
    Jun 2016
    Coatesville, PA
    12
    Algae control. Unopened.
    Sand Filter
    TF-100 Test Kit
    Apr 2010
    East Texas
    9,648
    Pitch it!
    Jun 2016
    Coatesville, PA
    12
    Quote Originally Posted by woodyp View Post
    Pitch it!
    Sent from my XT1030 using Tapatalk
    Lol I suppose that means it's trash.
    Sand Filter
    TF-100 Test Kit
    Jun 2016
    Coatesville, PA
    12
    Would this be accurate? And is there a preferred method to adding powder CYA to the pool?
    Sand Filter
    TF-100 Test Kit
    Jun 2016
    Coatesville, PA
    12
    I used the panty hose technique I saw others use. Put about 3.8 lbs in and tied it off in front of the return jet.
    I'm gonna let it do its thing. Leave the pump run until it is dissolved and then check my CYA again.
    Sand Filter
    TF-100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    More here on pool chems and how to add them to your pool, Pool School - Recommended Pool Chemicals
    Use Poolmath, link above, to calculate the dose.
    Add your pool info to your signature so that we can better help you as shown here, Pool School - Read This Before You Post
    Do some reading in Poolmath
    Start here ABCs of Pool Water Chemistry
    And here, Pool School - Getting Started
