Results 1 to 11 of 11
Thread: White stuff on swg?????
    I have this white stuff on my swg cell. I can't get my pool above 3.5. Could this be why?
    Intex AG 2252 / 10421 Gallons / Vinyl liner
    Pool Set up - May 2016
    2650 gal/hr Intex Krystal Clear Pump- Type B Filter
    Intex SWG
    TFTestkit / SpeedStir Magnetic Stirrer!!! / BBB method only
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: White stuff on swg?????
    Yes, that is scale build up on the plates. That cell will need to be removed and cleaned with a diluted muriatic acid solution. I think the ration is 5 to 1 water to acid. And as always, the buildup will be lessened with proper water balances. Got a set of test numbers we can look at?
    Fc. 3.5
    cc 0
    ph 7.5
    cya 65
    ch 125
    ta 80
    Intex SWG
    Apr 2010
    East Texas
    9,659
    That looks pretty dog gone good. When or has the cell ever been cleaned and how long in service?
    We set it all up the week before memorial day. We tried to move our old pool to the new house but the liner ripped and had several holes it.. so we got the 22 ft pool. Everything is new.
    I run a full set of numbers at the beginning of each month. I'm running a new set now.
    Intex SWG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Those numbers are good, but the scale on the SWG does not lie. Enter all your test results in Poolmath and it will calculate your CSI score for you. Keep that number between -0.6 and 0 to prevent scale. Tweak PH and TA to adjust it.
    More here about Calcium Scaling
    We had A LOT of rain so my cya and salt dropped. Will correct that today.
    Intex SWG
    LFrankow's Avatar
    Sep 2012
    Medicine Hat, Alberta
    502
    Scale on an Intex cell could mean that the circuit whichs reverses the polarity isn't working right. The Rectifier in my first one died, so I adapted the cell to run just using a 12 volt battery charger, I would then manually turn the plug over to the SWG daily to reverse the current and self clean the cell. Last year I installed a DPDT switch on a half hour timer which reverses polarity every half hour. End of season inspection of my salt cell showed it looking in brand new condition.
    To help your SWG, once cleaned, bring your FC level up bump your CYA into the 70 - 80 range as per instructions in
    Pool School - Water Balance for SWGs
    Lou - 13.5K Gal pool, AG Intex 24 X 52"
    19" Sand Filter/1 hp pump, Aqua Trol SWG
    90 sq ft Homemade Solar panels + 80 sq ft Fafco panels, coupled with a SS heat exchanger/Hot Water Tank, Pentair SolarTouch, Taylor k-2006
    Looks like I need to balance my pool today.
    Is there a link with instructions on how to clean the swg cell on TFP? Intex manual says to use vinager. Will that take the scale off the cell?
    Intex SWG
    DFW, TX
    24,516
    Vinegar is fine. If it isn't strong enough then you can use a 5 to 1 dilution of muriatic acid. Always add acid to water and never water to acid.
    Would this be a good time to add borates with 20 mule. It will raise pH by 0.77, raise Borate by 6, and raise TA by 14. I was planning on doing it one box at a time anyways. Then I can bring my ph back down to lower ta back to 80.
    Intex SWG
