Thread: Changing Sand
    Changing Sand
    How do you easily get the filter head off? Hayward 300lb. sand filter top mount head. Its hard plumbed with pvc pipe so I dont see a easy way to get the head off to get to the sand.
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    Re: Changing Sand
    If it is hard plumbed, there isn't any easy way to remove it. Sometimes there are unions near the filter that allow you to disconnect the pipes and open up the filter.
