Thread: Replacing Filter valve and 3 way valve
    Jul 2015
    HARRISBURG NC
    11
    I recently replaced 12 year old single speed Pentair with a Super-flow Variable speed. Noticed some fine cracks pipes thread into filter valve and also I over tightned the old pump coupling causing a crack on suction side but does not leak, I will replace with new couplings that came with pump.
    • current filter valve is Pac-Fab TM12-A. Suggestion on replacement of valve and should I replace all internal parts
    • What 3 way valve is best ?
    • Currently has Nature 2. But I do not have a cartridge installed. Do not plan to use. Should I just remove when I re plumb ?
    Thanks in advance for any suggestions
    25 year old construction
    20x40 In vinyl 36k gal
    2 skim 3 returns
    Pentair super flow VS, Sand Filter
    TF 100 test kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Replacing Filter valve and 3 way valve
    Jandy neverlube's are the best 3 way
    I would just take the nature 2 out
    you can use these, make sure they are 2 inch, they have the same 1,5 inch if you need them
    Amazon.com: 2 PACK -CMP Hi-Temp Union 2 Garden
    I hope this helps
