Thread: Pentair minimax nt 250 e04 vacuum problem
    Jun 2016
    Lakeland fl
    1
    Hi. This is my first post here but you guys have always been a good point of reference for looking up any information.
    I have a Pentair Minimax NT 250. Never had any problems with it and I only use it about 8 times a year. I use it exclusively for heating my Spa. It gives an E04 error code after running for a few minutes. Fan starts but burners don't ignite. Fenwal Ignition board has a single red flashing light (designated as air flow fault on the board). If I remove the hose from the fan assembly and suck for a minute, the burners ignite and the spa starts to heat. Soon as I remove my lips from the hose, the burners cut out and the ignition board has a single red flashing light as before. I've clean the nipples on the fan assembly and on the air pressure switch with a paper clip to no avail. This morning I fitted a new air pressure switch but that made no difference.
    is there anything else I can do? Is it worth getting a new flange to see if I can get a better seal ($20) or am I wasting my time and I should buy a whole new fan assembly ($300). The fan runs fine and isn't noisy in any way.
    Any help appreciated!
    Stuart
    ps0303's Avatar
    Jul 2011
    FL
    3,681
    Re: Pentair minimax nt 250 e04 vacuum problem
    Check the squirrel cage on the blower motor and make sure it's intact. Doing what you did on the air tube tells me the air switch appears to be operational so I suspect a bad motor squirrel cage.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Sep 2014
    Oregon City, OR
    3
    Stuart, did you resolve the issue? I have the same heater for my pool and just encountered the same issue. I'm curious to know what you found out!
    Thanks in advance.
    Brian
