Thread: Hayward maxflo xl only runs on low speed
    Jun 2016
    cape coral, fl
    4
    Greetings everyone,
    I have a Hayward SP2310x152, two speed 1.5hp pump. Probably about two years old.
    Just bought the house and trying to figure everything out.
    Pump is controlled on a foot pressure switch that operates like so
    1 - pump on low
    2 - pump on high
    3 - pump on high and blower on low
    4 - pump off (i think) and blower on high
    I would prefer to eventually rewire it so that the blower operates independently from the pump.....
    the pump runs on low just fine...on high, a loud buzzing for 1 sec and then it is shut off.
    Cleaned the basket, didnt feel anything around the impeller, contacted Hayward customer support with no luck.
    any suggestions?
    here are my numbers, if they help
    total c 5ppm
    free c 5ppm
    cc 0
    ph 7.5
    total alk 100ppm
    calcium hardness 245ppm
    stabalizer 75ppm
    total dissolved solids 3,600 ppm
    Any suggestions???
    first pool ever, learning something new everyday.
    meat
    12000 gal exposed aggregate pool with integrated spa
    In ground, screened pool cage
    Jun 2016
    cape coral, fl
    4
    Re: Hayward maxflo xl only runs on low speed
    just heard back from Hayward tech support, they said "verify wiring correct and voltage to the pump is sufficient, if it is you have a bad motor"
    dammit.
    Jun 2012
    western NY
    1,559
    Knowing how two speed motors re wired, I am inclined to agree with them. Have you verified all connections are good and the proper voltages are present at the right times at the right places?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
