I have a Jandy power center/pad and SWG system (1400) that was installed in 2006. When I went to put the system in service mode this morning and attempted to turn on the pump, cleaner, or any other features using the buttons on the control panel, I heard a metallic click and the feature failed to turn on. I've unscrewed the control panel to look at the SWG controller and noticed that the LCD display is blank and the power light is off. Any idea what the problem would be?
EDIT - I forgot to mention that the lights above the buttons on the front panel turn on when I attempt to turn a feature on using the front panel buttons while in service mode, but the feature doesn't turn on, just the sound of a loud metallic click but nothing else.
I've had issues with questionable pool service folks in the past and could use a referral for a reliable, honest pool service tech in the North East DFW area (Allen/Frisco/McKinney).
fwiw, I've learned so much from this site. The information here is worth it's weight in gold.
Thanks in advance!
Thanks in advance!
