Thread: Do I need to bother adjusting TA?
    Sep 2015
    Rome, NY
    363
    Many of you is probably followed my threads on here since I am new to this. Thanks for all the help.
    6/19 results
    pH 7.3 and holding nicely
    TA 90
    I think my pool likes being at that level. This morning's results after swimming and adding fill water, approximately only 1-1.5" --- total alkalinity of fill water is 400.
    FC 4.5
    CC 0.0 so happy
    pH 7.5
    TA 160 surprised it went this high with so little fill added. I'm sure with some math I could say I am wrong.
    CYA 50
    adding 42 oz of 10% bleach.
    BUT, so I bother with the 55-65oz of MA?
    or wait and see how the TA affects pH?
    My my log shows my pool isn't a fan of a TA of 160.
    Maybe I just answered my own question???
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Do I need to bother adjusting TA?
    The only real reason to actively lower TA is to stop PH rise so you don't have to add acid so often. But, adding acid to lower PH will also slowly lower TA. So, it will get there eventually.
    Sep 2015
    Rome, NY
    363
    So for now let it ride?
    DFW, TX
    24,516
    If you have some time to burn by the pool today I might spend a little time lowering to 120 or 100 to help move the process along. Pool School - Lower Total Alkalinity. But, if not, it is fine too.
    Sep 2015
    Rome, NY
    363
    That's what I've been following.
    Threw some Ma in and will be back in by 1700 today.
