Results 1 to 9 of 9
Thread: pH level constant increases
    Thierry's Avatar
    Jul 2015
    Québec
    6
    This is my first post, so I hope I follow correctly the forum's rules.
    So, first and foremost
    FC 6
    pH 7.8
    TA 90
    CH 260
    CYA 40
    I've tried lowering my pH and TA level last weekend. I had to put twice as much "pH-" product as per directions to achieve 7.2 (product was bought at the pool store and there were no indications about what was the active ingredient nor the concentration).
    This weekend, pH is back up at high levels with everything else stable.
    I need your help! Thanks in advance!
    2006 24000 Gal IG Vinyl Pool - Hayward S-244T Sand Filter - Hayward super pump 1.5 HP - Liquidator 8gal. 3/8 upgrade with bleach - Taylor K-2006
    Owner since 2014, learned everything from this incredible community
    Have a dwell, but can't use its water since scarce / I use the river water
    Secondary house - can't take care of it every day
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: pH level constant increases
    Are you aerating the pool any by any means?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    You will probably find using muratic acid to lower pH will be less expensive than the Pool Store. I would check Canadian Tire because you can get almost anything there.
    You will find that pH naturally wants to rise in most pools. Aeration from water movement causes it. Even having a return jet pointed up causing ripples on the surface raises pH. Waterfalls and kids splashing speeds up the process.
    So, to slow it down you have a couple of things you can control.
    TA - the higher your alkalinity the faster pH rises. I keep my TA in the 50 - 60 range to slow the rise
    Where you keep your pH. Higher pH tends to rise slower. So, shoot for pH of 7.5 or 7.6 rather than 7.2
    With a little trial and error you will find your pools sweet spot to slow the rise, but seldom do can you eliminate it.
    Support the site
    Thierry's Avatar
    Jul 2015
    Québec
    6
    If you mean by circulating water with pump, yes. Otherwise, I don't know what you are talking about
    Apr 2010
    East Texas
    9,609
    I mean, a SWG, screwed in aerator to a return or a running water feature.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    By "running water feature", Woody is talking about a feature such as a fountain or waterfall that exposes the water to the air. For example, the pH in my pool tends to drift up due to a spillover spa where the spa is connected to, but raised above, the pool surface. This results in a waterfall when the valves are set to circulate water among the spa and pool. However, the pH will tend to stabilize around 7.6 - 7.8 and stay there for a while before needing to be adjusted.
    Thierry's Avatar
    Jul 2015
    Québec
    6
    Quote Originally Posted by tim5055 View Post
    Thanks a lot. Aeration is a good hypothesis since I leave the pump on most of the time (I am away most weekdays).
    Also, I though adding muriatic acid would complicate the lowering of TA. No?
    Also, recommended levels of FC for the Liquidator is 7.2-7.4 I believe.
    Thierry's Avatar
    Jul 2015
    Québec
    6
    Quote Originally Posted by BoDarville View Post
    I see. I don't have that feature, except for occasional water slide use.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Adding MA to lower PH will slowly lower TA. At some point TA and PH will reach equilibrium and the PH will either stop rising or slow substantially.
