Results 1 to 10 of 10
Thread: Wet concrete blocks on above ground pool
    Jul 2015
    Windham, NH
    49
    We are in the process of building a deck around our above ground pool when we noticed the concrete blocks that the pool is sitting on are wet on he back side of the pool. We just recently built the pool and I just started running the filter yesterday. Late yesterday my husband noticed that one of the blocks was a little wet that is the base to one of the columns for the pool. This morning all the blocks for each column along the back side are a little wet. One is especially wet. Any ideas other than a leak? It's a brand new pool with new liner. The water level doesn't look lower.
    Thanks
    13,541k g, AG, SHarkline Heritage 24', Hydromax AC DE95 Filter, Vinyl
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Wet concrete blocks on above ground pool
    Is there any condensation on the walls of the pool?
    Love TFP? Become a
    TFP Supporter!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    High ground water seeping up with the extra pressure in that area??
    Jul 2015
    Windham, NH
    49
    No Condensation along the walls.
    It's only wet just around the footings of the pool that sit on the blocks. Our well is low only because when I topped off the pool water we drained our well and had to wait an hour for it replenish. The entire block is not wet.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Hmm all very good possibilities mentioned so far.
    What type of liner is it? Overlap, beaded? Has anyone swam it it yet? I ask because if it is a beaded liner and it's been swam in than there is a good chance that water being splashed about gets up and on top of the bead. That water then drains to the where the bead tracks meet, which coincidentally is right in the middle of every post. The water will seep down the wall and get into the bottom track and drain out onto the paver making it wet.
    This is exactly what is happening on ours, several pavers were damp. Initially I panicked thinking we had a leak on our just installed pool! But it turns out that after a day or two of no use and this summer heat that the water dries up. Took me several days of watching people and the water to figure out it was just splashed up water draining out the gaps in the bead receiver.
    If you've swam in it than maybe that's all it is on yours as well. Fingers crossed it's not a leak.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Jul 2015
    Windham, NH
    49
    We haven't swam in it yet. I'm just about to slam it. We ran the filter for the first time yesterday. It's an overlap liner.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Well poo. I was hoping it would have been something simple like that and put your mind at rest. So being an overlap and no swimming yet totally blows my suggestion out of the water.
    Let's hope it's the ground water being pressed out from the extra pressure.
    Can you see any amount of moisture in the bottom tracks along where the wet pavers are at? Is this wet area close to the skimmer?
    Jul 2015
    Windham, NH
    49
    There does seem to be water in the track as well. The wet pavers are close to the skimmer but some of them are a little ways away from the skimmer. It's all the pavers along the side of the pool with the skimmer.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    It's possible that you just need to tighten up the screws on the skimmer plate. It could have a small leak around the gasket. Any water that seeps out will eventually end up in the bottom track and that can carry the water around to several different spots where it can then escape at each joint and create a damp spot at each area making it look worse than it is.
    Jul 2015
    Windham, NH
    49
    Ok, thank you...I'll try tightening the skimmer. That could be it....I hope!
