Thread: Control Heater Remotely
    Aug 2014
    Wendell, ID
    6
    I've got a Jandy LXi 400N heater and the Aqualink Z4 controller.
    The control panel for the Z4 I had moved away from the equipment so we can control it all closer to the pool. The problem is that the control of the heat was never wired up to the controller. So in order to change the heat I have to go back to the heater and change it there.
    But that's only part of the problem. Because the controller doesn't know when the heater is or isn't running it will shut down the pumps before the heater has sufficient time to cool off. Last year this caused the heater to melt the plastic headers on each side of the heater. It looks like it may be happening again this year. So I would really like to get this wired up.
    Can anyone help explain how to make this work. I've looked over the manuals of both units and from what I can see I have to run wire from pins 1 and 2 on the green terminal bar on the Z4 to the Pool and Comm pins on the LXi 400N and turn on the REMOTE in the service mode of the heater.
    Well, I've done this, but it doesn't appear to work. When I change the heat setting with the controller it doesn't change the heater behavior.
    Any suggestions?
    40,600 IG 20' x 45', Pebble Tec Pebble Sheen Aqua Blue, Jandy 1.5 HP pump, Jandy 460 sq ft filter, Jandy LXi 400N Heater, Aqua Star Chemstar Inline Chlorinator, Paramount PCC 2000 In-floor cleaning system with Jandy 1.5 HP pump, Cover Pools Save-T3 automatic cover, AquaLink Z4 Control Panel, SR Smith 8' Jump Board, SR Smith TurboTwister Slide.
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Re: Control Heater Remotely
    So you wired it up to the heater, set the heaters temp all the way up on the unit and then you put it in remote mode and you can't turn the unit on from the Z4 if you set the temp higher than what the current water temp is? Also, do you have the water temp sensor installed on the Z4?
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Aug 2014
    Wendell, ID
    6
    That is correct. However I only set the spa temp all the way as that is what I found in the directions. I'll try the pool temp as well and see.
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    You only need to set one temp on the heater. The automation system will control the rest. And you have the water temp sensor installed for the automation?
    Paul
