Thread: FC Instructions and Chart
    Aug 2014
    Ventura CA
    3
    Hello, I have been looking at this site for a long time and it has helped me a lot with my pool. I want to give the responsibility of daily FC test and adding of chlorine to my Gardener. I made him a instruction sheet (english & Spanish) and a table that shows how much chlorine to add. He will be using my TFTest for this. If there is something screaming wrong please let me know! see attached. I hope it is of use to someone else as long as they put in their own chlorine info based on water volume of their pool, etc.
    Pool & Spa Shared System 27,000 Gallons
    IG, Plaster,
    Filter Pentair FNS PLUS 60
    Pump Pentair Inteliflo VF
    Hayward SWG
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: FC Instructions and Chart
    Welcome to TFP!
    It depends on how conscientious your Gardener is. The instructions and principle is easy enough to follow, but it all comes down to execution. I would still spot-check periodically. Hopefully, your chart takes into account chlorine demand at different times of the year.
    Aside from chlorine, how are the other parameters (pH, CYA, TA, CH) going to be managed - by you or the Gardener? While these parameters do not move as quickly as FC, they will drift over time.
