Results 1 to 9 of 9
Thread: Dolphin m4 problem
    Dolphin m4 problem
    Hi.
    I have a dolphin m4. The controller turns on, lights up etc, but when I press the button to move the cleaner nothing happens. I assume the motor is blown?
    How do I diagnose the problem?
    Thanks
    Phil
    (1) St. Louis, MO. (2) 18-20K kidney shaped (3) DE FNS Plus 48 (4) Salt System (IC40) (5) Pentair Intelliflo 3HP (6) 24 x 7 (7) Dolphin M4
    Captain 776's Avatar
    May 2016
    Thailand
    163
    Re: Dolphin m4 problem
    How long have you had it? Does the place you bought it have the expertise to diagnose the issue? Send Maytronics an e mail and ask them for their manufacturer recommendation.
    I bought an S-1 and I think it is fantastic, even when my pool looks very clean and I let it do a 2 hr cycle the filter frames come out black and catch so much you can see. I swear by it. When I bought mine they had a promotion where you get an extra fine filter basket in addition to the just the basic screen. I also like that it is self contained and all that it catches never enters your main filter.
    let us know how you make out with this.
    I know of another S-1 problem where the machine will not climb the walls but have no resolution yet.
    Bruce
    8M x 4M X 2M no slope IG CONCRETE w/ceramic glass tile
    17,000 Gal EMAUX SWG JAZZI FILTER W/1-3 mm glass media, Jazzi Multi-port valve with
    T-750 filter w/ glass media
    1 main drain sump -3 returns - 1 skimmer
    Kokido digital salinity tester, Kokida drops for CL Hanna digital PH meter, Taylor K-2006
    I've had the cleaner three years I think. It gave out at the end of last season.
    I bought it on line, so no real help there.
    One of the reasons I bought this particular model was because I believed it could be maintained by the user. I.e. Parts could be swapped out etc.
    I'm surprised no one here has had to diagnose one of these or replace the motor etc. 😕
    Phil
    My first guess is always the power supply. Do you know anyone with a similar unit that you can borrow?
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,205
    Quote Originally Posted by Geebot View Post
    This would be my first thought and step to diagnose.
    Plus, I would give these guys a call. They are a Maytronics service scented and are good with DIY folks. Marina Pool Spa & Patio
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Quote Originally Posted by phild View Post
    I'm surprised no one here has had to diagnose one of these or replace the motor etc. ��
    Phil
    There probably are people here with that knowledge. Either give them some time to notice the thread and respond or do a search for previous threads in the upper right corner.
    INYO Pools has lots of Maytronics how-to info and parts diagrams. Here's one, Maytronics Dolphin Supreme M4 Parts - INYOPools.com
    BobbyR's Avatar
    Jun 2013
    Toronto, Ont
    142
    Have you tried pressing the reset button? That always fixes mine when it occasionally decides to just sit there when I press the start button.
    Lagoon 40x22, Vinyl, 27,000 gal, 1HP WhisperFlo Pump, Pentair 60 gpm Sand filter, Hayward Brominator (used for chlorine pucks only when away), Rheem gas heater, Dolphin M4 Robot
    Waterfall on separate dedicated pump
    Thank you all for the responses.
    yes, tried pressing the reset button.
    This is what happens:
    If the cleaner is not plugged into the power supply/controller and I turn on the controller, the on switch lights up and the three 123 lights blink for a few seconds, then just the on switch is lit.
    If the cleaner is plugged in then the on switch lights up momentarily (maybe a second) and then goes off.
    wrt the cleaner.
    The impeller at the top turns, though will not freely spin (I would not expect it to).
    The tracks will turn, again not freely (I would not expect them to).
    So, it appears there is nothing jamming either the tracks or the impeller.
    Other thoughts?
    Phil
    Other thoughts?
    Phil
    Power. Supply.
    Geebot
    Chicago, IL
