Thread: What is the best place to buy Taylor K2006 reagent refills?
    Sep 2015
    Setauket
    39
    It has been the 1st year that I use Taylor K-2006 to test my pool myself. (Actually 1st year to own a pool.) I wonder what would be the best place to buy some refill.
    What I do need is the following.
    1. CYA test. I think I do need a lot of it. The original supply can barely test 10 times or even less.
    2. Chlorine test. (the powder thing.) I some time test 3 times per day when I did the SLAM.
    3. PH test. (not the base/acid reagent. but the ph indicator.)
    thank you very much.
    20'x 40' 32000 gallon pool. (built approx in 2001.)
    Vinyl liner (replaced in 2017)
    Pentair FNS Plus 48 DE filter
    AutoPilot Salt Chlorine Generator.
    Pentair Whisperflow pump w/ Variable Speed V-Green 165 Pool Pump Replacement Motor
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: What is the best place to buy Taylor K2006 reagent refills?
    Here is the place - TFTestkits.nett K-2006 refils
    Support the site
    Sep 2015
    Setauket
    39
    Thank you.
