Thread: Liquid Pools Covers
    May 2016
    Windsor/ON
    14
    Liquid Pools Covers
    Ok, as the title says, I was wondering if anyone has used this product?
    http://www.liquidpoolcovers.com/ecosavr.htm
    What effects if any should I be concerned with if I were to add it to the pool?
    Thanks for the feed back!
    22,000 gal IG 18x30 Roman pool w/ vinyl liner
    Hayward Swim Pro sand filter
    1.5hp 240v Hayward pump
    Zodiac LM2-24 SWG & Digital timer
    Taylor K-2006 Test Kit & K-1766 Drop Test Chloride Salt Water
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Liquid Pools Covers
    In most cases it won't work. Search the forum as this has been discussed many times over.
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,461
    Most folks vote no. A few use it because it is better than nothing. Barely and if the wind isn't blowing. The wind will blow it all to one side of the pool and it won't work at all.
