Results 1 to 12 of 12
Thread: Old guy, Old pool, Leslie's didn't help.
    Jun 2016
    Antioch, CA
    5
    Been reviewing the forum after getting frustrated with the amount of TriChlor powder I was pouring in.
    Ordering test kit, but all the cheap test kits indicate the CYA is in the hundreds. Which I believe..
    Pool meets all the symptoms, takes lots of chlorine to keep it clear, PH was really low, brought up with Borax. So switched to only liquid chlorine. Two gallons a day seems to be holding off algae.
    So knowing only way to reduce CYA is drain/refill and California is still in a drought, what can you do with the water?
    I have a hose connection on the pressure side of the pump.
    Wash vehicles? Dump it on lawn? (going to remove it anyway). Pressure wash house and deck?
    Seems I should block the skimmer intake so it pulls from bottom of pool.
    Orchard
    In ground pool with attached spa - 18x32 with diving board, built in 1989ish. Estimate at 30000 gallons. Hayward 2hp pump, C3000 with cartridge filters. Polaris 360 cleaner
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: Old guy, Old pool, Leslie's didn't help.
    Welcome to TFP!
    Folks in water rationing areas do have problems.
    You can Google your area and see if reverse osmosis is available in your area.
    Why would you block the skimmer??
    Support the site
    Jun 2016
    Antioch, CA
    5
    I thought I read in one of the posts it is better to drain water from the bottom of the pool rather than from both skimmer and main drain. Or does it matter?
    May 2014
    Franklin, NC
    9,197
    Quote Originally Posted by orchard53 View Post
    Nope, doesn't matter. Some believe that CYA is near the surface but that is incorrect. CYA is in solution throughout the water column.
    Support the site
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Blocking skimmer intake to draw only from bottom? I'd be reluctant myself to do this with pump running. Even though I have valves to shut off intake from skimmers, I'd be reluctant to run the pump to drain only from floor drain once below skimmers.....I think mine would still suck air even with valves closed but maybe I'm wrong.
    I know from experience with my setup where pump and filter are lower than the pool water that if we leave the filter on backwash or waste without pump running, it drains. ALOT. It's happened twice here when "somebody" left the filter handle on waste.........hoping it isn't a habit of this person. It seems like a watched pool never fills.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jun 2016
    Antioch, CA
    5
    Well found a person in the area that does reverse osmosis, will see what it costs.
    May 2014
    Franklin, NC
    9,197
    The last cost I saw was $550 for up to 25,000 gallons. Plus, there is an amount of waste water that will also need to be taken into consideration.
    Support the site
    Jun 2016
    Antioch, CA
    5
    Preliminary quote - A 30,000 gallon pool would be $1000.
    Ouch.
    38,521
    Yup, almost always cheaper to replace the water.
    Jun 2016
    Antioch, CA
    5
    Slowly replacing water in pool....  And wife likes water warm...  Chlorine costs, but is keeping wife happy.
    May 2014
    Franklin, NC
    9,197
    keeping wife happy.
    Very good idea!
    Support the site
    Oct 2015
    Katy/Texas
    411
    I would use the water from the pool for your yard and other outdoor needs. That way it's not wasted.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
