Thread: Going on vacation and my pool eats Acid
    May 2015
    katy, tx
    31
    I recently had my pool replastered so it is taking a lot of acid. Daily doses, knock it down to 7.2 in the morning and it's back to 7.8 or 8.0 in the evening. I'm working my TA down some more to see if that will help. The question I have is, will a high PH for a week hurt much, start scaling, etc or am I good for that amount of time and shouldn't worry about it.
    Numbers since everyone asks.
    Chlorine - 7.0
    TA - 70
    CYA - 50
    PH 7.2 to 7.8 depending on the day. Right now 7.4
    CH - 300
    Salt - added for feel and overshot - 2800 (kids loved it)
    I use a peristaltic pump to add bleach nightly.
    16,500 gallon in-ground pool and spa with Quartzscapes Midnight-blue and pretty sparkles
    Aqualink RS with PDA
    Jandy Pro Series Plus HP 2 HP 2 Speed Pump
    Jandy CV460 Cartridge Filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Going on vacation and my pool eats Acid
    No, it isn't that big of a deal. It is sustained high or low PH for months that creates the problems. If you get your TA down to 60 before you leave that should help a bit. That is a pretty fast rise though. Are you running any waterfalls or bubblers? If yes, run them less or none to help reduce the PH rise.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    My new plaster had pH rise almost that fast. Drop it to 7.0 right before you leave, high pH for a few days won't cause any problems.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    May 2015
    katy, tx
    31
    I dont run my waterfall on a regular basis right now for this reason. Really only when we are swimming or hangin out outside at the moment. Then I check the PH and adjust if necessary.
    It's good to hear it won't mess things up for a week. I wasn't looking forward to another pump for acid as I know this rise should go away and become relatively stable. I don't plan on having the waterfalls run while I'm gone.
    Thanks for the quick replies.
    Also my pool water looks awesome due to the advice on this site. Wish I found it before I built my pool.
