Results 1 to 11 of 11
Thread: Filter pressure problem
    Jul 2012
    Richmond, Va.
    43
    AG pool with a 1 HP Hayward matrix pump
    Last year got a new sand filter, Hayward 18"
    Last summer it ran at about 15 Psi after backwashing.
    Starting this season I noticed it runs at 25 psi.
    Everything seems to work fine. Could I have a problem or maybe the gauge went off over the winter.
    Thanks for any info
    PS: have a Lomart skimmer and next time I replace the liner will replace that with the Hayward skimmer. Does anyone sell a repair plate with the cut out already in it, to repair a AG pool wall?
    6014 gallons aprx
    cartridge type filter
    summer escapes pool above ground metal frame
    SFS1000 SkimmerPlus filter pump with GFCI=1,500 GPH
    install date: 6-1-12
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: Filter pressure problem
    I would be suspect of the gauge. I seem to need a new one every year almost and have driven myself batty thinking something else was wrong when pressure was abnormal.......only to replace gauge and see it was fine. I actually bought 2 last time I went to pool store for one.
    I don't know about the parts question but Inyo Pools online has a lot of pool parts.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    mas985's Avatar
    Pleasanton, CA
    11,737
    Does your filter gauge go to zero when the pump is off? Have you backwashed/cleaned the filter?
    Mark
    Jul 2012
    Richmond, Va.
    43
    Quote Originally Posted by mas985 View Post
    Yes does go to zero. Been running it over a month this year so have backwashed a few times. I think its working ok. No sand coming out. Acts normal when I backwash.
    6014 gallons aprx
    mas985's Avatar
    Pleasanton, CA
    11,737
    But after the backwash, does the pressure go back to 15 PSI?
    What is the make/model of your pump?
    Mark
    Jul 2012
    Richmond, Va.
    43
    It did last year. This year after the winter it goes to 25 PSI.
    1 Hp Hayward matrix pump AG
    6014 gallons aprx
    mas985's Avatar
    Pleasanton, CA
    11,737
    I would backwash now and see if it goes down.
    Mark
    Jul 2012
    Richmond, Va.
    43
    Nope. Did backwash today, and still the same as last week and week before.
    6014 gallons aprx
    mas985's Avatar
    Pleasanton, CA
    11,737
    Sorry just noticed the filter type. Cartridge filters don't normally backwash so what exactly did you do?
    Nothing else changed since last year?
    Mark
    Jul 2012
    Richmond, Va.
    43
    Nothing changed since last year. But it is a sand filter
    Hayward S180T filter
    6014 gallons aprx
    mas985's Avatar
    Pleasanton, CA
    11,737
    Sorry, I was going by your signature. But since it is a sand filter and assuming your gauge is good, it could be the multi-port valve or maybe something internal that is causing the higher pressure.
    Mark
