Thread: Prepping for a party
    Nov 2015
    Chicagoland, IL
    205
    We're going to have a bunch (read 30+ people) over for a pool party in about 2 weeks (First one! Much excited!).
    How early should I bump up my FC? I've read that it would be acceptable to bump it up to just under SLAM level - for us, SLAM is 12, so Aiming for 11?
    People will be here for about 4 hrs - should I test during swim time? Can I add chlorine if needed during swim time, and if so, how to safely do so?
    27,000 gal. plaster IG with round spa built in 2007. TFT-100 test kit XL w/ Speedstir
    Jandy CL580 cartridge filter. Jandy 1.0 hp filter pump, 1.5 hp booster/spa? pump.
    Aqualink RS One Touch controls. Paramount PC2000 In-floor cleaning system (1.0 hp pump?). Jandy LX pool heater, apparently broken.
    Missing so much gear due to previous foreclosure, it's sad.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Prepping for a party
    I do it the morning of. I would go about 8 ppm. Doing a quick test a couple of hours in is a good idea. And then boost to 8ish after. Make sure it stays above minimum at all times.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    You should be fine doing that. I woulnt worry about testing during the party unless you just want to... or maybe if you did test, you could show off your chemistry prowess and do a show and tell!
    Divin Dave,
