Thread: Installation of wall foam around skimmer intake and return
    Jun 2016
    Middle River, Maryland
    1
    I am installing Wall Foam on a new above ground pool. There are no instructions from Gladon or on their web site how to install it around the Skimmer intake and around the return. I am applying it with the spray adhesive. Do I cut the foam out around these areas before I apply the foam or cut it out after applying ect. Any help is appreciated.
    Thanks Allen
    Swim and Play Deluxe 8000 10x15 Pole Pool above ground. Installing now
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Installation of wall foam around skimmer intake and return
    Welcome to TFP
    I think most cut it out afterwards
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    I was researching the use of wall foam before setting ours up. I believe I read to cut it after you've glued it in place. Also remember reading to cut several inches back from the openings to allow for a tighter seal around the gaskets of the return and skimmer.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
