Results 1 to 11 of 11
Thread: Chemicals unbalanced.
    Jun 2016
    Lesage, WV
    14
    First time pool owner. It's an above ground polygroup Summer's wave 18X4. Shocked it last weekend and the levels are unbalanced. And there is stuff in the bottom. I have vacuumed it and cleaned the filter. The stuff is back. I don't know if is algae or just dirt.
    Total hardness 0
    Total chlorine 10+
    Free chlorine 10+
    Ph 6.8
    Total alkalinity 0
    Stabilizer 0
    My question is what do I need to do to make it safe to swim in?
    Jun 2016
    Lesage, WV
    14
    first time pool owner. Chemicals unbalanced
    Using Clorox test strips
    Total hardness 0
    Total chlorine 10+
    Free chlorine 10+
    Ph 6.8
    Total alkalinity 0
    Stabilizer 0
    The Clorox app says I need
    Chlorine stabilizer
    Ph protector
    Ph down
    Calcium hardness increased
    And to wait until the chlorine leaves naturally.
    Me and my husband just brushed and vacumed the pool and cleaned the filter, hoses and pump. Still testing the same.
    Jun 2016
    Lesage, WV
    14
    Re: Unbalanced above ground pool
    Prior to shocking the total hardness, ph and total alkalinity were in the idea range. But stabilizer, and both chlorines were 0
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Chemicals unbalanced.
    The first thing is to pick up a good test kit. You can get either a TF-100 or a K-2006C. I recommend going to TFTestkits.net and get that on order, right away.
    While you are waiting for that to arrive you need to read a few pages.
    Pool School - What is TFPC?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    38,546
    Yup, you need a test kit. Some of those numbers are not really possible.
    And if the CYA is really 0 and the FC is really that high, then it is not at all safe to swim in.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    CH of 0 is nearly impossible. TA of 0 and PH of 6.8 is impossible. Those test results must be from a pool store or a test strip. +1 to a good test kit as the first step.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: first time pool owner. Chemicals unbalanced
    The first thing I will do is to buy a recommended test kit and read pool school, more people will chime soon... Good luck
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    May 2015
    Mount Cheaha Alabama
    250
    using the Clorox test strips is a guessing game even with the analyzersi they've installed at Wally World If you're chlorine is really high they don't measure the other items very well
    its kind of like a digital pool store salesman telling you to buy a bunch of their chemicals You need stabilizer cya use the pool math to calculate for 30-40 target
    30k in ground vinyl lined pool surrounded by decking in the woods.
    Hayward sand filter circa mid 80's
    If there is a way to do things less expensively and yield a superior product I am all ears
    Jun 2016
    Lesage, WV
    14
    I borrowed my neighbors test kit. Well he tested it. The results were pretty much the same. But after hours and $70+ the levels have settled. And turns out it wasn't algae it was pollen.
    And my husband had the pump hooked up backwards.
    We have no clue what we are doing
    DFW, TX
    24,516
    Read some Pool School to get an understanding of water chemistry.
    Start here, ABCs of Pool Water Chemistry
    And then here, Pool School - Getting Started
    Jun 2016
    Lesage, WV
    14
    I used my neighbors well he did it using the K 2006c. Results were pretty much the same. Slight difference. But after $70+ it is now balanced. He said we used way to much shock. And that it's not even algae in the pool. It's pullen. Plus my husband had the pump hooked up backwards.
    We have no clue what we are doing. But hopefully we can keep it balanced.
