Thread: Pentair Master temp 120v AC plug (12 pin receptacle)
    Hi, am new to the forum and find it to be very informative and active.
    I need to convert the red 240v AC plug (12 pin receptacle) to the 120v. Bought the heater off a guy and didn't check the input voltage. It came with 240v installed and the heater wouldn't fire . Read through the manual (should have done prior) and looked for the black 120v which i couldn't find inside the control box.
    Thought i try the forum first for a clear picture of the black 120v plug from current owners or simple schematic diagram.
    Online stores have it for $23 + ship.
    Thank you for reading and any help will be much appreciated.
    Pool heater = Pentair Master Temp 400 NA
    NEW POOL: Completed, 11/23/11
    44,000 gallons
    Filter: Pentair -model# CCP520, Cartridge, 150 GPM (17-8585)
    In ground ~ Pebble Sheen
    Pentair IntelliChlor IC40 ~ SWG
    Main and Small waterfall pump: IntelliFlo ~ 3HP,
    Big Waterfall pump: WhisperFlo ~ 1-1/2HP
    Polaris 280 F5 with Century Centurion 3/4HP booster pump
    Re: Pentair Master temp 120v AC plug (12 pin receptacle)
    Welcome to TFP!
    There is a good picture on page 28 of the online manual. I don't know of a wiring diagram that shows how that plug is wired. I think you are going to need to order one.
