Results 1 to 16 of 16
Thread: Always have algae on floor?
    88rxn/a's Avatar
    Jul 2011
    ludlow, PA
    34
    Hello,
    Even though I keep my parameters in check, I always find a little algae on the floor of my pool? the waters crystal clear when I take off my solar cover but the floor isnt?
    I sweep it and it's gone until a few days later. I had this problem last year too and I tried slamming the pool and even passed the overnight test, same as this year?
    I run my filter 4 hours every day on a timer and add my bleach every day.
    What gives?
    fc 4
    Ph 7.2
    Ta 70
    Salt 1,100
    Also, no matter how much borate I add ( I use the calculator and add the recommended amount) I cannot get my ph up.
    I have tried 3 times in the last week. I even tried a different test kit with the same results.
    24X4 round vinyl liner 160 jacuzzi sand filter
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Always have algae on floor?
    How often are you brushing your pool and running a pool cleaner/robot? Weekly brushing of the entire pool at a minimum is required, even if your running a cleaner. The cleaner can help improve circulation if it is run daily or a couple times per week. What is your CYA level?
    Isolated Spa - 345 Gallons
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Quote Originally Posted by 88rxn/a View Post
    Hello,
    What gives?
    fc 4
    Ph 7.2
    Ta 70
    Salt 1,100
    How are you testing, & what is your CYA level?
    Please post a complete set of test results including:
    FC
    CC
    PH
    TA
    CH
    CYA
    I would leave the PH where it is right now, 7.2 is perfect for a SLAM, and with visible algae, you need to SLAM the pool.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    88rxn/a's Avatar
    Jul 2011
    ludlow, PA
    34
    oops, sorry
    CYA 70
    FC 4
    PH 7.2
    TA 70
    CH 230
    CYA 70
    using a TF-100
    i have (i think its the name of it) a shark i only use on occasions, but i brush the pool at least once or twice a week before we swim.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Your FC is too low for your CYA. That is going to allow algae to grow. See Pool School - Chlorine / CYA Chart
    To get rid of the algae will require SLAM process.
    Also on the PH, you say you are adding borates but in what form? Borax will raise your PH while I don't believe boric acid will.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    88rxn/a's Avatar
    Jul 2011
    ludlow, PA
    34
    Wouldn't I go by the swg's fc goal since I added salt?
    I'm currently around 1,100.
    I am using the 20 mule team to try and raise my ph.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Sent from my SCH-I545 using Tapatalk
    Do you have a salt water chlorine generator? It's not listed in your signature.
    You are going to have to SLAM the pool, so leave the pH where it is. That is the starting point for a SLAM
    Support the site
    88rxn/a's Avatar
    Jul 2011
    ludlow, PA
    34
    No I don't have a salt generator. I use the blue solar salt bags.
    Judging by everyone's answer I'm slamming. ..lol
    I was under the impression that if I had salt in the pool it requires less chlorine? Am I wrong?
    If so, what's the difference from having a salt generator and just adding the salt from bags as far as the chlorine goes?
    May 2014
    Franklin, NC
    9,197
    Nope, just adding salt to the water does not decrease the need for chlorine. The salt generator is a device that converts the salt in the water to chlorine. It is a common misconception that a salt pool is not a chlorine pool.
    Right now you have salty water, but still need to add chlorine.
    Support the site
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    A salt water generator creates chlorine from salt in the water. If you are not chlorinating that way, you need to be chlorinating with liquid bleach as other dry forms of chlorine add unnessary things to your pool like calcium or CYA. Your CYA is already on the high side for a non saltwater (SWG chlorinated) pool so your chlorine should never drop below 5 or you have an open door invitation for an algae party in your pool.
    See the link I posted above for the chlorine CYA chart. You can click on pool school too and read up on ABC's of pool water chemistry.
    To rid the algae, you do need to slam then to keep it from coming back you need to keep your chlorine from falling below the minimum for your CYA.
    88rxn/a's Avatar
    Jul 2011
    ludlow, PA
    34
    thanks everyone!
    i am very well aware of the charts and how they work. what i did not know was that the salt water generators actually produced chlorine for pools!
    that's what had me so confused. i thought for sure i was supposed to use the SWG chart since i had "salt" in my pool!! hahahahahha!! boy do i feel silly!
    little did i know...
    live and learn i guess.
    Messman750's Avatar
    Jun 2015
    Groton New York
    34
    Now slam that pool 👍
    32x16 inground chlorine. 23000 gallon with diving board
    vinyl liner 1hp hayward super pump. Waterway sand filter new in 2014.
    maytronics dolphin m200 robot. I live in central NY.
    TF100 kit Taylor speedstir. Sonos audio
    88rxn/a's Avatar
    Jul 2011
    ludlow, PA
    34
    Still slamming!
    I was wrong on my cya, it is only 30. I was starting to get a little cloudy when I posted this but it's crystal clear again with a little algae on the floor every day when I remove the solar cover. I brush it all the replace the cover. And make sure I'm still at shock level and adjust it when needed.
    So I still have algae on the floor. I wonder how long it's gonna take?
    88rxn/a's Avatar
    Jul 2011
    ludlow, PA
    34
    An hour after I sweep the floor this algae is right back!?
    Am I doing something wrong?
    Jul 2014
    Hope Mills, NC
    569
    How do you know it is algae?
    Have you done the overnight chlorine loss test?
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    domct203's Avatar
    Jun 2015
    CT
    3,596
    How's your CC level? How many ppm of FC do you lose between tests/doses?
    How about posting a full set of test results.
    How well are you holding SLAM FC shock level? The longer you can keep the pool at shock level the quicker you kill algae.
    It's good that you brush to expose any algae to the chlorine. Keep it up and brush as often as you can.
    You're running the pump & filter 24/7, right?
    Stay the course, you can beat this!
    Dom
    Dom - TFP Guide
