Thread: CYA problems I need advice
    I'm having problems with my CYA in my pool. I thought I had figured it out last year reading your posts. At the end of the season when I closed my pool I drained it way down. Over e course of the winter (we had which was a rainy season) I drained it 2 more times. When I opened it up the CYA was around 60 so I thought I was good. Having to shock it to clear it up the CYA was raised up to around 90 but the water was clear and all the chemistry was perfect. Instead of using tablets I decided to use shock to maintain. I was using around 2 pounds every 3 days and according to your chart I was maintaining around 8 to 10 on the FC. The CYA has been steadily raising up which I have around 150 CYA now. I am currently draining again to get it back in specks. I have been using SAM's shock is there anything better I can use that will not raise my CYA? I can't keep draining and filling that will be too much on my well.
    My pool is an inground vinyl pool around 32000 gallons. I think the size is 16 x 32. The filter is a sand filter. The pool is around 20 years old. I have been operating it since 2006.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: CYA problems I need advice
    When you say "shock" what are you using? Granular chlorine is stabilized with either calcium (cal hypo) or CYA. You should be using liquid chlorine or plain unscented bleach.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Yes I am using granular chlorine. How much bleach should I use? How much will bring the FC up 1 ppm?
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Time to read Pool School, and I would suggest starting with this- ABCs of Pool Water Chemistry
    Adding only single ingredient chemicals to your pool makes it a LOT easier to keep track of your pool. And self-testing is the most important part. That granular "shock" product is not a great thing to be using as it obviously also contains CYA with the chlorine. Liquid chlorine (aka "bleach") is the easiest once you learn how to dose it. PoolMath is the application which helps there.
    PoolMath says 47 ounces of 8.25% bleach will raise your FC by 1ppm.
    Quote Originally Posted by YippeeSkippy View Post
    Thank you my friend. I will get some bleach tomorrow. This looks like it will be a lot better to use.
