Thread: .2 ppm iron
    Her pool boy's Avatar
    May 2016
    St Catharines, Ontario, Canada
    86
    .2 ppm iron
    In an earlier post I indicated that my first water test I did on my refilled pool from the pool store indicated I had .2 ppm of iron in the water. This seemed odd at the time since I filled with city water from the garden hose.
    Recently I did my first slam and had to maintain a FC of 16. I have just completed the slam and have notice no staining at all. Should I assume that I will not require sequestrant , and that either there isn't enough iron in the water to require it, or that the PS test was wrong?
    Any my advice as obviously don't want to use sequestrant.
    SteveS
    16' x 50' - 95K L (25000 gallon) I.G. Vinyl liner 12.5 Liquid Chlorine
    Wicor Pantera P24 Sand Filter Pentair Superflo Variable Speed Pump
    Zodiac 3510WD Robotic Cleaner Raypak R336A Heater. ​Taylor K2006c test kit
    JoyfulNoise's Avatar
    May 2015
    13,188
    Re: .2 ppm iron
    Municipal water can still have iron in it as iron is not considered a contaminant that needs to be treated. Many municipal suppliers will still treat for iron but they typically don't have to report it or do so only on an annual or bi-annual basis.
    The 0.2ppm level is near the bottom of the test range so I would probably discount this as pool store testing inaccuracy.
    Matt
    May 2016
    86
    Re: .2 ppm iron
    Thanks Matt
    SteveS
