Thread: Just curious - can high load of sunscreen cause cloudy?
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    109
    Can excessive bather sunscreen cause a cloudy pool or would it be that the sunscreen lowers the free chlorine and then algae makes it cloudy. I'm just curious, mine is sparkling.
    John
    27,000 gal concrete rectangle, built Oct '15, DE filter, Jandy PHPM 1.5 HP, Hayward HP21104T heat pump, TF-100
    Mar 2015
    US
    122
    Re: Just curious - can high load of sunscreen cause cloudy?
    Perhaps a bit of both. Any suspended particles in the water can make it cloudy, be it algae, sunscreen, pollen, dust, etc. Any organic matter in the water will increase chlorine usage. I'm not a chemist, so I can't comment on the effect of chlorine on sunscreen. More than likely however, high bather load will add more organics to the water and will therefore eat up more chlorine regardless of the amount of sunscreen that is added to the water.
    29,000 gallon vinyl liner custom designed lagoon style in-ground pool (self-built 2015-2016), Hayward EcoStar VS pump, Hayward HP21404T Heat Pump (140K BTU), Hayward Pro Grid DE DE6020 Filter with Fiber Clear, Hayward Tiger Shark, 2 Hayward Color-Logic LED lights, Stenner 45MPHP10
    370 gallon Jacuzzi J-345 spa with ClearRay UV
    Apr 2013
    Sacramento, CA
    2,769
    Depending on the number of bathers and how long they are in the pool yes.
    In my 23K pool 5 or six after a couple hours results in the water becoming slightly cloudy. I make sure my stenner pump is dosing the pool and that generally keeps it crystal clear or close too it.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Yup. High bather load wearing sunscreen can deplete the FC fairly quick. If you are going to lots of swimmers its not a bad idea to bump up the FC by 2 so you have a little headroom.
    If the water is cloudy, I wold recommend to go ahead and elevate the FC to SLAM level for a day to clear it up.
    Nothing wrong with swimming with FC up to slam level.
    Divin Dave,
