Thread: Lost my little blue measuring scoop for Chlroine test
    jgofnj's Avatar
    May 2013
    Hillsborough, NJ
    167
    Hey guys, was about to do my weekly test of my pool water using my TFTestkit when I realized the little blue scoop for the chlorine test was missing. I have no idea how I lost it, been testing with it for 4 years now. I guess I will have to order a new one. In the meantime, how should I go about testing the water? Is a little pinch good enough?
    20,000 gal, In-Ground (built in 2007)
    Vinyl lining / 1HP Hayward SuperPump / Hayward Pro-Grid DE Filter / Hayward Gas Heater / Liquid Chlorine,Bleach (4 Gallon Liquidator)
    Dohney Discovery Robot
    Testing Method: TFTestkits/TF-100
    JoyfulNoise's Avatar
    May 2015
    13,176
    Re: Lost my little blue measuring scoop for Chlroine test
    See if you can find something like this locally (plastic is better) -
    Amazon.com: Pinch Dash Smidgen Measuring Spoons: Sprinkle Dash Pinch Measuring Spoons: Kitchen Dining
    Adding extra powder is not a problem, adding too little powder can skew results. I use one of these -
    Amazon.com : Taylor Unit Dose Dispenser : Swimming Pool Chemicals And Supplies : Patio, Lawn Garden
    But note it only works with Taylor bottles not the bottle of powder that comes with the TF100
    Matt
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    You can use the end of a pocket knife as a scoop (its what I use), or a half a popsicle stick or anything that's small enough to get a little scoop of powder......
    Divin Dave,
    jgofnj's Avatar
    May 2013
    Hillsborough, NJ
    167
    Quote Originally Posted by jgofnj View Post
    Thanks!
