Results 1 to 7 of 7
Thread: Where is my baking soda going?
    DThompson55's Avatar
    Jun 2016
    Manchester, CT
    21
    I got my test kit on Thursday. I saw that my pH was low at 7.2 (I'd been taking my water tests to Leslie's before this and all this season they told me it was high > 8.0) So I added 2lbs of baking soda per the pool math calculator and let the pump run for a few hous. The next day I retested and the pH had barely budged, so I added another 2lbs. This morning, same thing, barely budged, so I added another 2lbs. Any thoughts as to where all that baking soda is going? Is there some kind of pH buffering going on? Or am I using the wrong chemical? This was my last bucket of Leslie's Alkalinity up, Sodium Bicarbonate
    15k gallon AG. Sta-Rite System:2 PLM-100 DE filter. Hayward Power Flo LX Pump. TF-100 test kit. Nice and Blue thanks to TFP.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,605
    Re: Where is my baking soda going?
    Ummm..baking soda is used to raise your TA. What does your test kit show that to be?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    More on pool chems here, Pool School - Recommended Pool Chemicals
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    I would also,recomend starting with ABCs of Pool Water Chemistry
    Support the site
    Jun 2016
    Manchester, CT
    21
    umph... my TA is 90, up from 70 when I tested it a couple days ago... wrong chemical... I was trying to raise my pH. I saw that pH is related to alkalinity in ABCs of Pool Chemistry, and I had this bucket of something called Alkalinity Up, so ... yeah... umph
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    oops! Not worries, it will come down with addition of MA.
    The TA controls how quickly the pH rises. Generally speaking, the higher the TA, the quicker the pH will rise....
    Divin Dave,
    If your ph was too low, you might need a higher TA. If your cya is high and you're using tabs, you might need a higher TA.
    How are you chlorinating?
    What is your CYA?
    Support the site
