Results 1 to 9 of 9
Thread: Teach me about my equipment?
    Jun 2016
    La Plata, MD
    50
    I know nothing, so I took some pictures in the hopes that you could tell me what they are (to put in my signature), and to make sure they are appropriate for my pool. My pool is a 28' octagon, 3' for 1/3?, then quickly goes to 6'. I guessed it to hold around 20,700 gallons.
    Wendy
    28' octagon, 21K gal, in-ground vinyl pool, single speed 3/4 HP Hayward pump, multi port valve on sand filter, using KS-2006 kit
    Nov 2015
    Carrollton tx
    451
    Re: Teach me about my equipment?
    Looks to be 3/4 hp pump based on the .55 kw that I can see
    the filter valve doesnt show much
    do you have image of filter model or heater ?
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a BaduŽ Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    The pump is a single speed 3/4 HP Hawyard pump.
    You have a multi port vavle on Sand Filter
    also add to your sig if your pool is in ground or above ground and if its a gunite pool or vinyl pool. Knowing this will help answer questions about your pool chemistry.
    Divin Dave,
    Jun 2016
    La Plata, MD
    50
    This is a picture of the whole set up. What are you wanting a picture of?
    Wendy
    Jun 2016
    La Plata, MD
    50
    Also, We don't have a way to "vacuum" the floors of the pool, other than a net bag type thing we attach the garden hose to. So that's only good for large debris, not the green algae gunk on the bottom of the floor. So if I were to purchase something to attach to the skimmer, or pump, or whatever, what do I get?
    Wendy
    mas985's Avatar
    Pleasanton, CA
    11,737
    The label with "To Pump" and arrow is backwards for the direction of flow. The arrow should point the other way and it should "From Pump". Arrow on the other pipe is wrong too.
    If you are looking for a suction side pump, ThePoolCleaner or what is now the Hayward AquaNaut is a pretty good cleaner.
    Mark
    Jun 2016
    La Plata, MD
    50
    Quote Originally Posted by mas985 View Post
    Is that something I should be worried about? Or just gee-wiz information?
    Wendy
    mas985's Avatar
    Pleasanton, CA
    11,737
    Just an FYI.
    Mark
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Hi Wendy,
    here is a link to a manual vacuum. Your brush / net pool connects to the pole connection thing and the vacuum hose connects on the coupling on top of the vacuum head.
    You will need a vacuum head, and a hose. The hose should be long enough to reach from your skimmer, to each end of the pool...
    Leslie's VH52CS/LES Deluxe Tri-Vac
    and vacuum hose - they come in various lengths
    Leslie's Forge Loop Vacuum Hose in Various Sizes
    and here is a video on how to do it
    How to vacuum an Inground Pool Video - YouTube
    Quote Originally Posted by kypovan View Post
    Divin Dave,
