Thread: Pleatco replacement filter vs OEM cartridge - Worth the savings?
    Apr 2014
    Central FL
    60
    Is the Pleatco PA120 just as good of a product as the Hayward CX1200RE?
    The Pleatco filter is $45. Compared to $85 for the Hayward.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pleatco replacement filter vs OEM cartridge - Worth the savings?
    everyone loves the pleatco filters, they seem to flow better and last longer and as you have already found they are cheaper
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    No, they are not just as good. They are better, cheaper, last longer, clean up easier than my OEM Pentair filters.
    poolnewbies5874's Avatar
    Aug 2015
    SW Ohio
    124
    That is so good to know! I just ordered 2 for replacements in our pool!
    12,000 gallon Blue Hawaiian 'Hamilton' fiberglass IG 15x34 freeform, Pebble Beach finish, Pentair Clean & Clear 100 filter cartridge, Pentair SuperFlo 1.5HP pump, Stenner pump, Raypak 266k heater
    8/2015 pool build photos TFT-100 test kit
