Thread: Question on a cover reel
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    117
    So, I'm tired of the leaves/flowers falling in our pool. I know I need a cover. My question is with a reel..
    We have a rectangle shaped pool & a diving board on one end, stairs on the other. Where would you put the reel? Or would you suggest just making strip's to more easily manage taking them off the surface?
    In ground Liner, MBP-125A Heat Pump by Aqua Heat , built 2003, 18x37 Grecian style, System 3 sta-rite filter. @22,000 gal, tftestkits TF-100 & 1766, USQ1102pump installed 6/2016, new liner installed 07/2017. Circupool SJ40 SWG ( to be installed 06/2018)
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Question on a cover reel
    they have some reels that are short to go under the diving board and the others have wheels on them to move them once rolled up... I think under the diving board is easier, no one has to move it..
