Results 1 to 12 of 12
Thread: Slammed for a week
    Jun 2016
    Woodstown/NJ
    10
    Slammed for a week
    I dont understand why I slammed for a week and still no improvement. It turned dark green to milky white but it won't clear.
    Ph..7.2
    Cyan..50
    Fc..20
    Tc..20
    Cc..0
    Calc..180
    36000 gallon hayward sand filter
    Filter sand was changed 2 years ago.
    Help
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Slammed for a week
    Well, a little more detail would help us help you.
    Please provide details of the pool.
    When you say you have SLAMed for a week, tell us what you have done and how often?
    What test kit are you using?
    What products have you put in the pool?
    Support the site
    Jun 2016
    Woodstown/NJ
    10
    Im using the taylor test kit recommended by trouble free pool,im using liquid chlorine 12.5%, checking readings multiple times daily, Ive passed the overnight test multiple days in a row
    May 2014
    Franklin, NC
    9,184
    If you have passed Overnight Chlorine Loss Test and have "0" CC then it can be time to add DE to a sand filter to help clear the water a little quicker. Instead of actual,DE powder, I use cellulose fiber DE replacement powder.
    Pool School - Add DE to a Sand Filter
    Support the site
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    455
    +1 what tim said... keep vacuuming and brushing, and keep your pump running until it's clear.
    The "milk" is dead algae, to remove it requires filtration.
    As your filter works to clear it, you will find yourself having to backwash a bit more than usual, (the dead algae will collect in your filter).
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2016
    Woodstown/NJ
    10
    Well im having to backwash less.
    Jun 2016
    Woodstown/NJ
    10
    The pressure isnt going up for the need to backwash, i even followed instructions to add de. No luck. Im only having to backwash every 2 days
    May 2014
    Franklin, NC
    9,184
    You have to give it time. In less than an hour after being told to add DE you are complaining that it isn't working
    If you are having to backwash every two days that proves it is filtering the stuff out.
    Support the site
    Jun 2016
    Woodstown/NJ
    10
    I have been adding dE after each backwash for 5 days now. Im not sure why you thought I just learned this and complained it wasnt working after an hour...confused yes...but anyway There is no improvement. I backwash every 2 days because Im at 10 psi and I clear it when it rises to 13. 2 psi over 2 days leads me to believe its a filtration problem
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Have you been taking pictures along the way? If so go ahead and post them. If not, take a few of stuff like stairs and ladders and post them.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    domct203's Avatar
    Jun 2015
    CT
    3,583
    Quote Originally Posted by Zumba57 View Post
    Sent from my VS986 using Tapatalk
    Nowhere in any of your posts do you mention already using DE in your filter, hence why it looked like you only gave it an hour.
    Is there anything else you have added but not mentioned?
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2016
    Woodstown/NJ
    10
    Well...ive given this a few more days and still cloudy. So yesterday flocked and now im crystal clear. I had my sand replaced yesterday, which was the problem behind my cloudy pool. Long story short, slamming ur pool will NOT cure a cloudy pool if your filter is not working properly.
