Results 1 to 11 of 11
Thread: You want reviews
    Marty D's Avatar
    Jun 2016
    Quogue new york
    146
    You want reviews
    I read and read and asked before I bought new pool equipment. At the time I didn't know about this forum. I ended up buying all Pentair. I'm happy I did. Just to add this. Yesterday I got my rebate check for $450 from pentair. $150 from PNG electric company. If anyone wants to know about pentair please fell fee to ask me. What I bought. Pentair variable speed VS-SVRS pump. Cost $750 rebate $150 pentair system 3 modular filter SM series. Pentair 140 elect. Heat pump. Our pool was closed for 7 years. Was not winteriz!! When we opened the pool there was trees growing from the steps. Black water with leaves 3 ft. Deep. After just vacuuming the pool without replacing the water, the system 3 cleaned that water in 14 days. If anyone is looking for a heater, that 140 heat pump gets the water from 74 to 84 deg in 24 hours. Cost to run it a month is under $100 a month. Weather and temp plus size will change. If I went with Gas vs Electric, the cost would be much higher. Pool has about 32,000 gall. Water.
    Inground 30x60 vinyl W/2 French ends w/sitting spa. Built 2007. 2016 pentair electric 140 heat pump. Pentair VS-SVRS pump. System 3 modular filter SM series S7m120
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: You want reviews
    That's quite an impressive cleanup considering the condition of the pool. Any chance of before & after pics?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    nice, I do love Pentair
    Marty D's Avatar
    Jun 2016
    Quogue new york
    146
    I'm trying to download pict but the file says full and will not let me add more pict. I mark the old pict so they will take them off.
    Jul 2013
    Fletcher, OK
    3,353
    you can only do one picture, if you support the site you can add more or check out my link below on adding pictures
    Marty D's Avatar
    Jun 2016
    Quogue new york
    146
    Ok I will. I was able to delete the two pict in file but I see it took off the pict I posted ?? I'm having a hard time dragging the pict Down
    Jul 2013
    Fletcher, OK
    3,353
    if you delete a picture it deletes it off your thread, not recommended
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Quote Originally Posted by cowboycasey View Post
    How do we support the site?
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    459
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Thanks.
    Marty D's Avatar
    Jun 2016
    Quogue new york
    146
    Can you show me that water fall. I found a water pipe from pool to pump that's not connected. I was told its for a water slide they had. We don't want to put a slide but maybe I can do a fountain?
