Thread: Dolphin Dynamic Won't Climb
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    We have a Dolphin Dyamic automatic cleaner. The parameters were set up for Not Climbing. We wanted to change it for climbing, so changed the parameters and let it transmit. The cleaner would not climb. Then I tried climbing using just the joystick, and still it wouldn't climb. I then turned off the cleaner, turned it back on, re-transmitted the data, but still it won't climb.
    Does anyone have any ideas? Thanks!
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Re: Dolphin Dynamic Won't Climb
    It might be too heavy, if you have removed any of the floats try replacing them. The bag might need cleaning, try running the bag through the laundry. This can also sometimes happen when the water is very cold.
    Apr 2009
    S.E. MI
    570
    Thanks, Jason! We've haven't ever added weights to it. The bag was filled with fine silt so I washed it. Yes, the water is cold (only 65 degrees). I wonder why the cold water temp would keep it from climbing. I finally located my manual and it says in there too that temp should be 65 or above. Hopefully this will work now.
    Thanks again!
