Thread: Please help me understand my plumbing - 3 suction lines and 1 sucks air?
    Jul 2015
    Atlanta
    39
    Figured it out. . may all my problems in life be figured out before I get a reply to a question!
    Mar 2015
    US
    122
    Re: Please help me understand my plumbing - 3 suction lines and 1 sucks air?
    Maybe it's for a vacuum? Do you have a port somewhere for a vacuum hose to plug in? You could maybe trace it by blowing air from a shop vac into the suction lines at the pump with the skimmer and drain valves closed. Then listen for the noise of escaping air or bubbles in the pool.
    29,000 gallon vinyl liner custom designed lagoon style in-ground pool (self-built 2015-2016), Hayward EcoStar VS pump, Hayward HP21404T Heat Pump (140K BTU), Hayward Pro Grid DE DE6020 Filter with Fiber Clear, Hayward Tiger Shark, 2 Hayward Color-Logic LED lights, Stenner 45MPHP10
    370 gallon Jacuzzi J-345 spa with ClearRay UV
    Jul 2015
    Atlanta
    39
    Dave, That was exactly it. I didn't realize it because there was a "discharge port" on the line, but it certainly is a vac line. I'll be hopeful that my leak is in that line alone!
    Thanks!
