Thread: New Pool Build In Wisconsin
    Apr 2016
    Sturgeon Bay, WI
    2
    Hi and Thanks to everyone responsible for this site, it is a great resource of knowledge and fellowship. I am currently building a new IG plaster pool, looking for any information on northern climate pool builds ? I am looking forward to getting to know everyone here ! JB7
    18X36 IG, Oyster Quartz Diamond Brite Plaster sport pool, 1/2 inch rebar 12" on center both ways with 20" X 12" bond beam, 10" thick walls/floor. 18,000 gals, Pentair variable speed pump, Pentair Intellichor IC20, S300 Dalphin Robotic cleaner, 2- Deck Jets, Pentair sand filter, CNTi 200k heat exchanger, Locking Automatic safety cover.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New Pool Build In Wisconsin
    Welcome to TFP
    Check out the new builds section, tons of ideas
    Apr 2016
    Sturgeon Bay, WI
    2
    Thanks Casey, I was wondering if anyone has any experance with heating pool with a outdoor wood boiler ? I heat my home and workshop with a Central boiler and was planning on heating my new pool build with the same boiler using a heat exchanger. Any thoughts on the proformance of an heat exchanger ? John
    Jul 2013
    Fletcher, OK
    3,353
    here is one, I have not seen many do them but I think they are really kewl and you can cook a pizza while you ate it
    Wood Stove Pools, WSP Profile, www.woodstovepools.com - The Best Wood Burning Pool Heater On The Market! -
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
