Thread: Booster Pump Leak?
    dmccoyTFP's Avatar
    Jun 2016
    Gonzales, LA
    19
    Booster Pump Leak?
    Is it normal for the booster pump to be leaking water when the filter is running? I'm assuming not so I turned the filter off. Any ideas what could be causing this and how to fix? Pics attached.
    David McCoy
    11K gal, IG fiberglass, Hayward self-priming pump, Pentair FNS Plus filter DE filter, Polaris cleaning robot, TF-100 test kit
    Apr 2015
    tucson, arizona
    1,137
    Re: Booster Pump Leak?
    Your shaft seal is leaking, even though it's not on water is running through it
    dmccoyTFP's Avatar
    Jun 2016
    Gonzales, LA
    19
    Thanks for the reply. Any idea the approximate cost to fix it, if I did it myself? After checking our home warranty, this should be covered (we added the pool as part of it). The service call fee is $100. Just trying to weigh the cheapest alternative - trying to fix it myself which would definitely be a learning curve or calling them.
    David McCoy
    Apr 2015
    tucson, arizona
    1,137
    The shaft seal is less than $10.00 and a new volute o ring is a couple of bucks. As long as the impeller is okay not warped. There might be video on how to replace on you tube.
    dmccoyTFP's Avatar
    Jun 2016
    Gonzales, LA
    19
    Quote Originally Posted by kadavis View Post
    Thanks again. Are these parts I should be able to get at my local pool store?
    David McCoy
    dmccoyTFP's Avatar
    Jun 2016
    Gonzales, LA
    19
    I was able to find some how to videos online and take it apart. One of the seals was definitely cracked. I'll check with my local pool store tomorrow and see if they have the parts. If not, I guess online is my next best bet? Thanks again for the help. Much appreciated.
    David McCoy
