Thread: Which testing method do you use?
    May 2016
    Lincoln Park
    10
    Do most of you use the 10ml mark to test chlorine or the 25ml mark? Is there a reason? A time where one is preferred over the other?
    I figure the 10ml is fine and will save on reagents, but I'd like to know what you guys recommend?
    Thanks as always,
    Nick
    INTEX AG Oval Frame 2885 gallons
    Intex 2500 GPH cartridge pump
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Re: Which testing method do you use?
    Absolutely just the 10
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,535
    10 for me also!
    Kim
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Use10. There is no real reason to test at 25. The only reason it's there, is just because "you can if you want to".
    Personally, I prefer the taste test!
    Divin Dave,
