Results 1 to 8 of 8
Thread: Liner tear
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Liner tear
    Upon further inspection, I have a tear in my liner... unfortunatley its in the bottom. IS there any way to temp repair a liner underwater? I dont want to drain and replace just yet.. The tear in only about 1/2 inch long and in an area that wont see much traffic. I plan to replace in the future but im hoping this will last until fall
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Apr 2016
    Hurley
    34
    Re: Liner tear
    Yep you can patch it underwater. If you have an overlap liner cut a small piece of the excess overhang and use it instead of the flimsy patch that comes in most repair kits. If not try going to the pool store and see if they have any scrap vinyl.
    30' Round Doughboy AG (diy install on 8/30/16 after 2 months of rock removal to level area LOL) 200lb Hayward sand filter w/ 1.5 HP pump. TF-100.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Liner tear
    sometimes pools stores have big pieces of patch vinyl you can get, I would use about a 4 inch piece
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Re: Liner tear
    Yes, you can apply the patch under water. Boxer adhesive works well under water. Cut 2 patches with rounded corners, 1 1" bigger than the tear all the way around, and the 2nd patch 1" bigger around than the first. Apply the smaller patch first, then the 2nd patch.
    Love TFP? Become a
    TFP Supporter!
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Liner tear
    I have plenty of overlap I can cut.. What is boxer adhesive and where can I get it?
    13500 gal
    Casey's Avatar
    SW PA
    10,453
    Re: Liner tear
    It's glue for patches. Check pool store.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Liner tear
    would rubber cement work?
    13500 gal
    Aug 2009
    SW Wisconsin
    518
    Re: Liner tear
    NO! get the correct vinyl repair glue from the pool store.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
