Page 1 of 4 1234 LastLast
Results 1 to 20 of 63
Thread: Breakpoint chlorination
    Lori5548's Avatar
    Jun 2016
    Ada, Mi
    55
    I have a 25,000 plaster pool with attached spa. This year since opening I can't get much of a free chlorine reading. I use the bio guard test kit but I did just buy the Taylor 2600. If the free cl test sat, it would eventually get fairly pink. The guy at the pool store told me just to walk away from the test and come back in 15 minutes. After doing some research I think I have a high combined chlorine. I shock with 5 gallons of liquid shock Monday night. Tuesday am I was registering adequate free but by the afternoon it was low again. The test at the pool store showed .5 free chlorine, and 2.5 total chlorine. It is calling for me to add nine bags of burnout 73. My cya is 35. Everything else is good. The water is clear but the hot tub does smell when it's running. Advice?
    Thanks
    Lori
    Mar 2015
    South Texas
    411
    Re: Breakpoint chlorination
    There is a tab at the top of this page where you need to start. It is called Pool School and it will answer all of your questions. It will be confusing at first, but reread it over and over and it will begin to make sense.
    Do not trust the pool store. For example, letting the sample sit for 15 minutes is horrible advice. That Taylor 2600 is a good kit, trust your results.
    The first thing you need to do is an OCLT to see if you have nasties in your water (I suspect that you do).
    Post a full set of numbers here and we can help
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Lori,
    you have a good test kit in the 2006.
    If you are loosing FC quickly, which you seem to be, and have high CC, which you do, then you are verge of an algae outbreak. Since your water is still clear, it wont take you long to fix it.
    Here are SLAM instructions. With emphasis on the M for Maintain.
    Trouble Free Pool
    And Pool Math
    http://www.troublefreepool.com/calc.html
    and here are TFP recommended levels for your pool.
    Pool School - Chlorine / CYA Chart
    Divin Dave,
    Lori5548's Avatar
    Jun 2016
    Ada, Mi
    55
    I knew having the sample sit was bad advice. I am going to take your suggestion on the pool school and am research the test you talked about.
    thanks
    lori
    When testing free cl and adding the fas/dpd titrating agent, the sample turns clear but then gets slightly pink again. Do I keep adding a drops till this stops?
    thanks
    lori
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Lori,
    no. Dont keep adding drops. When it goes clear, then thats the end of the FC test.
    When you test for CC's you need to add the R0003 immediately (or within a 1/2 minute), of the FC test.
    Divin Dave,
    Lori5548's Avatar
    Jun 2016
    Ada, Mi
    55
    Thanks so much Dave!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    You're welcome!
    Quote Originally Posted by Lori5548 View Post
    Divin Dave,
    Lori5548's Avatar
    Jun 2016
    Ada, Mi
    55
    Free CL .5
    CC 2.0
    TA 120
    CA 195
    CYA 48
    advice on how much to shock? I have a bunch of burnout 73 that I would like to use.
    thanks, lori
    20x40 25,000 gallon gunite w/attached spa caretaker system stayrite system 3 filters Hayward Lxi heater Taylor 2600 test kit
    38,248
    What is your CH? That burn out will add calcium and may cloud up the pool.
    Lori5548's Avatar
    Jun 2016
    Ada, Mi
    55
    Calcium is 195
    38,248
    OK.
    We do not "shock" our pools. You need to use PoolMath and follow the ShockLevelAndMAINTAIN Process.
    Lori5548's Avatar
    Jun 2016
    Ada, Mi
    55
    Ok, thanks
    Lori5548's Avatar
    Jun 2016
    Ada, Mi
    55
    So using pool math I put in 6 bags of 73 triclor and woke up to 1 free chlorine and 7 combined. What next?
    38,248
    That makes me suspect that you really have CYA in the water ....how did you get those numbers?
    You need to keep adding chlorine, and I would suggest switching to liquid.
    Lori5548's Avatar
    Jun 2016
    Ada, Mi
    55
    So I'm at a loss. Retested now numbers inverted. FC 7 CC .5. CYA 39. Only thing I added since this am was 10ml algecide. I have had trouble with pink slime last couple summers late in summer.
    Lori5548's Avatar
    Jun 2016
    Ada, Mi
    55
    Just tested again. Numbers inverted again. 1.0 FC 6 CC has anyone seen this before? This has been happening at the pool store as well using the bioguard testing.
    Jun 2014
    15,008
    Lori, part of the problem may be that you're combining chemicals and pool care methods. Applying algaecide is not part of the SLAM instructions, so it's very possible the elevated CC is from the chlorine destroying the algaecide. At the same time, the algaecide you added may have added metals to the water (copper), none of which are good. SO now would be a good time to trust your K-2006 test kit and the SLAM page exclusively. The SLAM instructions will work, but you have to be consistent and patient. When it comes to algae, there are no overnight/quick fixes. Just stick to the regular bleach and everything else on the SLAM page. Very important .... maintain that SLAM FC level and test frequently to ensure you do so. Good luck.
    Your last recorded CYA was 40, so your SLAM FC level is "16".
    Lori5548's Avatar
    Jun 2016
    Ada, Mi
    55
    How long do I swirl the 0870 powder? The longer I swirl the darker it gets. During slam do I add bleach during day when sun is out?
    Jun 2014
    15,008
    Do you use the speed stir or manually swirl? When you are testing FC, you keep swirling the powder and adding drops while counting until it goes clear. That's where the speed stir really comes-in handy so you have one hand free. For the bleach - yes, you add anytime day or night as required to "maintain" that FC of 16.
  20. Back To Top    #20
    Lori5548's Avatar
    Jun 2016
    Ada, Mi
    55
    What is speed stir vs manual?
