Results 1 to 8 of 8
Thread: Intex Fountain - Its tooooo strong
    Apr 2016
    Casa Grande, AZ
    66
    Hi,
    OK - finally getting around to attaching the Intex LED fountain - simple enough right? Except that since I upgraded to a bigger pump to solve the issues I have posted about before - when attaching it close enough to the return hose from the pump it sprays all the way OVER our 9' rectangular pool!!! Of course I figure there MUST be a way to adjust - right? Directions say - get a smaller pump!!! ARRGGHH..
    SO, my plan is to put ON the 9' side of the pool and then it will be fine. BUT, the return hose is not long enough - and I only have one extra piece of hose right now and it will doesn't have the correct connection - they both have the threads with the big gray plastic tightener.
    I said - OK - just to test it I can pull a couple of hose from the robot - even though I don't really want to keep taking it in and out when using the fountain (I have posted earlier that it really is just my wife that uses this pool and just floats - so leaving robot in all the time is preferred).
    BUT, I am still having a major mental roadblock as to whether there are any of THOSE pieces of hose that will connect to the pump return hose - I don't see any of those with the right connection either?
    I am absolutely sure at this point I am just missing something - and I will just go BUY another hose to keep connected to the fountain - but I need to make sure I get the correct one!
    Help - I am thinking that INTEX probably sells an extra long pump return hose - but then I still have to connect/disconnect at the pump all the time....
    TIA.
    Intex 18'x9'x52 - 2800 GPH Sand Filter/Pump - TF100 Test Kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Intex Fountain - Its tooooo strong
    you are at the point of needing to hard pipe its better all around, you can actually use what you have and control how much water goes to where and where the suction comes from, it really is easy once you start
    intex hard plumb - pump to 1.5 pvc
    Another rectangular Intex over-the-seam skimmer and hard plumb thread
    https://www.google.com/search?sitese...lefreepool.com
    domct203's Avatar
    Jun 2015
    CT
    3,593
    Quote Originally Posted by cowboycasey View Post
    Agreed, hard piping will make it convenient to add T-fittings & valves.
    Here is how I have mine hooked up:
    Independent flow control to either the fountain or return.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jul 2016
    Jackson, MS
    9
    I just installed an intex fountain on my 22ft agp and it shot nearly 3/4 the way across my pool. I took the 4 screws off the bottom and there is a plunger that bypasses some of the water flow. I took the spring off the plunger so it bypasses more water and now it shoots out about 3-4 foot so it's perfect!!!!
    domct203's Avatar
    Jun 2015
    CT
    3,593
    Quote Originally Posted by Switchbackxt View Post
    Where is the bypassed water going if it is not coming out the fountain? Is it just running out of the seams or something?
    Once the water enters the fountain from the hose attachment fitting it really has no where else to go but out of the sprayer.......
    Dom
    Dom - TFP Guide
    Jul 2016
    Jackson, MS
    9
    It comes out the bottom into the pool, mine was spraying about 16-18 ft and was also coming out the bottom. I'm just allowing more water to come out the bottom into the pool.
    Jul 2016
    Jackson, MS
    9
    The plunger on the bottom is some kind of pressure release I assume. It has a spring on it so when the pressure is too much it pushes that spring down and allows the plunger to open and let water bypass. I'm guessing my pump was pushing too much pressure and was allowing it to bypass. If your pump never pushes too much pressure you would probably never see it come out the bottom. P.S. Nice set up Dom, you take pride in your work.
    domct203's Avatar
    Jun 2015
    CT
    3,593
    That makes perfect sense. I only have a 3/4HP pump, and don't run the valve to the fountain wide open for the reasons already mentioned so I would never experience the bypass.
    And thanks for the compliment!
    Dom
    Dom - TFP Guide
