Results 1 to 8 of 8
Thread: Intex filter pumps??
    Jun 2016
    Semmes, AL
    26
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Intex filter pumps??
    Everyone who has bought that pump loves it, the only one better is the saltwater generator pump because it makes your chlorine on the spot
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    That is the one that I have, very happy with it, but also I have a separate SWG
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jun 2016
    Semmes, AL
    26
    Hey Piolin, what sand did you use and how much did you put in?
    Roc Davis: My pool. 18 x 48 Summer Waves Elite, Intex 16" 3000GPH Sand filter pump combo, TF100
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    It was 120 pounds of
    HTH pool sand purchase at Ace Hardware store... 😊
    Starting day 5/25/2015 INTEX AGP 24'x12'x54" 8,400 gal, with salt and borax, INTEX 3,000 GPH pump with 16"sand filter, WM Hayward Skimmer, Intex SWG CG-28669, 1 1/2" hard plumbed PVC, Lil' Shark Vacuum With Leaf Canister, TF100 test kit, speed stir, K-1766 Taylor salt test
    Jun 2016
    Semmes, AL
    26
    Awesome thanks
    I have had mine for 3 years now, I have the separate SWG. Those two changes have truly made my pool an absolute pleasure, my maintenance is extremely minimal I love it!!!
    Intex 18'x48" Ultra fram 6400 gallon Intex SWG
    I bought one this season to replace cartridge type filter. I love it. Low maintenance and easy to run. I did cut off the GFCI plug and replace with a standard plug to run it with a mechanical timer (the timer is protected by a GFCI outlet). This increases the ease of use. I am able to run the filter twice daily (for about 5 hrs each time). With the GFCI plug it would trip every time the mechanical timer clicked on. I also paired this pump with a SWG and it's perfect.
    Coleman 16'x48" Ultra Frame (5100Gal)
    1500GPH Coleman filter
    Intex SWG 7110 (7k Gals)
