Thread: Calling All Hayward ProLogic Jedis–Trying To Control Heat/Cool Heat Pump
    Jun 2016
    Orlando
    2
    I have a Heat Siphon dual (heat and cool) heat pump, model z575HC. It will operate in three modes–Heat, Cool, or Auto. I'm in Central Florida and use the unit for both heating and cooling. I recently installed a Hayward ProLogic unit to control new Hayward Echostar, booster cleaning pump, water feature, lights, fire pit, etc. I'm a novice programming ProLogic, but there doesn't seem to be a way to control the Heat Siphon unit from the ProLogic unless it is in "Heat" mode only. Any one have any ideas or suggestions?
    This is only used on pool. There is no spa.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Calling All Hayward ProLogic Jedis–Trying To Control Heat/Cool Heat Pump
    Welcome to TFP
    You may have to call tech support on this one, not many have that exact automation that could help
