Thread: Cloudy Water Post Shocking
    Jun 2016
    Charleston, SC
    2
    About a week ago, we had a very bad storm and my pool turned green because of it. I read in my booklet that came with the pool test kit that to treat the problem, I needed to add 30 ppm FC all at once. I did that, and now my water is cloudy. How can I get it to not be cloudy? I did the algae treatment 3 days ago, and slowly the system is filtering out the cloudiness, but I was hoping I could get it to go faster.
    Thanks.
    38,262
    Re: Cloudy Water Post Shocking
    Please add your pool details to your signature as described HERE as it will help us help you.
    What test kit are you using?
    Well, I hope your pool is not vinyl with low CYA as raising that FC that high would likely cause damage.
    We teach to follow the ShockLevelAndMAINTAIN Process when there is a problem in the pool.
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
