Thread: Under contruction in Kansas
    Jun 2016
    andover
    1
    Hello everyone,
    New to the forum and new to pool ownership. I have finally caved to the demands of the family and got onboard with the idea of getting a pool. Currently there is a rather large hole in the back yard with panels set in place and that is about all so far. The only question I have so far is that is there anything anyone wished they would have done while the pool was under construction? It seems like I still have time for changes or different ideas. Thanks for any help!!
    Vinyl Lined in-ground Pool 18 x 35 Lagoon Shape. 8ft deep end
    Jandy Remote Control System
    Liner Upgrade Black 27 Mil Textured w steps
    Jandy Variable Speed Pump
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Under contruction in Kansas
    Welcome to TFP
    as much deck as you can afford
    umbrella spots in the deck
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    if your steps will be outset from the main body of the pool, put a return on each side of the steps so the debris will be blown out. Otherwise, its a daily task brushing the dirt off the steps.
    Divin Dave,
