Thread: Sand Filter Pump setup questions
    Jun 2016
    Semmes, AL
    26
    My wife and I just ordered a 18 x 48 Summer Waves Elite Ultra Frame Pool. I have done some research and see that upgrading to a sand filter and pump seems to be the way to go. I have look at a couple of intex models and need advice on which one to purchase or are these junk and need to look else where. Please help these are the two I'm looking at.
    Amazon.com : Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 2800 GPH Pump Flow Rate, 110-120V with GFCI : Swimming Pool Sand Filters : Patio, Lawn Garden
    Amazon.com : Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 3000 GPH Pump Flow Rate, 110-120V with GFCI : Swimming Pool Sand Filters : Patio, Lawn Garden
    38,267
    Re: Sand Filter Pump setup questions
    Bigger is better, especially for the INTEX pumps/filters.
    So, get the 3000GPH with the larger sand filter for $18 more
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Hayward makes a great pump/filter unit... don't count them out
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    38,267
    Quote Originally Posted by cj3737 View Post
    Sure, but for $158???
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,521
    The Intex pumps work well enough, but I found myself only getting 2-3 years out of one before it died. So this year I sprung for one of these: Pro Above Ground Swimming Pool Pump System 4500GPH 19 Sand Filter w/ 1.0HP - Walmart.com
    The only drawback is you have to adapt it to your pool's hoses. Leslie's sells adapters for Intex hoses, two for $9.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    True but in my experience with intex products, they only last a few years... I would imagine a pump in the same category as Hayward and pentair but well below the price point sounds kinda sketchy. I looked at them when I was shopping just based on price but still decided on the hayward
    13500 gal
