Results 1 to 9 of 9
Thread: Hello, Thank you, Pool School Testimony
    BigJer's Avatar
    Jun 2016
    Fayetteville, NC
    3
    Thank you for the quality of this site.
    Had a 16ft pool about 15 years ago. Very unsuccessful experience. Lack of knowledge.
    Found Pool School and began studying. Installed a new 15000 gallon above ground vinyl pool 6 weeks ago. The pool is used daily for therapy and recreation. It is very clear cut keeping it balanced and healthy using TFP. We started with the chlorine, and PH. Then the CYA to protect the CL. Next we raised the total alkalinity. Finally added the boric acid just today to protect the PH. I particullarly like the pool calculator forecaster where I can do "what if" calculations, so I know the full impact before adding chemicals. Every question I came up with I was able to find answers to on this site because somebody else had the same question before me. Thanks again for helping to simplfy the mystery of having a healthy pool.
    CL 4
    PH 7.4
    TA 70
    CA 40
    CYA 30-40
    Borate 40-50
    Temp 88
    Size: 15000, 32'x16'. Above Ground. Vinyl w/metal frame. 2,800 gph pump w/16" Sand filter. MFG Model: Intex 28647EG
    Maintenance Method: TFP. Test Kit: K-2006. Chlorine source: 10% liquid CL. CYA: 35, Borates: 45.
    38,290
    Re: Hello, Thank you, Pool School Testimony
    Welcome to TFP!!!
    This is great to hear!!! You have clearly been doing your research
    If everyone did that, we would start to get bored around here
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum! Great testimony.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Awesome story. It's gratifying to read that someone actually read pool school, incorporated it and isn't trying to reinvent the wheel.
    nice job on keeping your pool troublefree!
    Divin Dave,
    Jun 2014
    15,144
    Enjoy your weekend!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Great job!
    I will just point out that TFP is run by volunteers and exists through the donations of folks who feel they received value from the site.
    Support the site
    BigJer's Avatar
    Jun 2016
    Fayetteville, NC
    3
    Quote Originally Posted by tim5055 View Post
    Thanks for the reminder, and now I have taken care of that.
    Thanks again for the terrific work you all do.
    Jun 2014
    15,144
    Thank YOU for becoming a TFP supporter. Badge looks good.
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by BigJer View Post
    Thanks!
    Looks like the lights are on for a couple of more days....
    Support the site
