Thread: Should I slam?
    Jan 2015
    San Jose, CA
    237
    Should I slam?
    had to leave for a few days and forgot to raise my chlorine level, came home to a pool with algae climbing on the walls although the water is still clear.
    Temp 87
    FC- .5
    CYA - 50
    Ph 7.5
    CC- 0.5
    I know most will say slam it but it doesn't look bad, according to the charge, I'll need to bring my FC to 20ppm for slamming? That's over 400oz of chlorine or about 3.5 gallons of chlorine I'll need to dump in there.
    Also, when I slam the pool, should I brush the walls and let the filter pick it up or leave it and watch it go away before scrubbing?
    SF Bay
    ********20,000 gallon IG Fiberglass, DE Filter, Hayward Max-Flo VS, Taylor TF-100 Test, Circupool RJ-45********
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Should I slam?
    Yes.......SLAM is in order if you have algae. Yes.....brush brush brush at the very least once a day. More is better.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jan 2015
    San Jose, CA
    237
    Re: Should I slam?
    Thanks, just finished dumping 4 gallons in the pool and brushed it, gonna go pick up some more chlorine and come home and brush some more.
    SF Bay
    phenol red's Avatar
    May 2016
    Twin Cities, MN
    22
    Re: Should I slam?
    If the walls even feel slick with algae you are mere hours away from a full blown algae bloom. Continue SLAMing and brushing until you pass the OCLT.
    30k gal in-ground, vinyl liner, Hayward 300 ft2 cartridge filter, 1 hp pump, Hayward 250k btu natural gas heater
