Thread: powder chlorine.......
    Does anyone know of a powder chlorine that doesn't increase the cya and lower ph? Is bleach the only option? THANKS
    25,000 gallon....36x18....inground vinyl....hayward 1 1/2 h.p. pump.....pentair de filter
    Re: powder chlorine.......
    You should read How to Chlorinate Your Pool. All forms of chlorine have disadvantages.
    Cal-hypo comes in powder form and does not add CYA or lower the PH. But it does add CH, which will eventually become a problem.
    Mar 2007
    Coastalish 'down easter'
    The cal-hypo also needs to be pre-dissolved before adding it to a liner pool!
    Luv& Luk
    If you don't mind spending the money you could use lithium hypochlorite but be aware that it is the MO$T EXPEN$$IVE form of chlorine there is. It is fast dissolving and has very few drawbacks
