Thread: How often do you need to drain your pool?
    Sep 2011
    Atlanta Ga
    310
    I have not drained my pool since I first filled it when I bought this house 5 years ago. The water is gradually replaced by rain and hose and evaporation, but I have never drained it and refilled it. Everything seems fine. Is there any reason to drain and refill?
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    Jun 2014
    15,139
    Re: How often do you need to drain your pool?
    No need to drain it unless the CYA or CH levels were not managed properly allowing them to get too high.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Drain and refill is usually what a pool store will tell you to do when they are out of ideas on what new chemical potion to sell you, that won't do any more than the rest of the junk they've already gotten you to buy.
    No need to do it if you are still keeping your pool maintained the way we teach here.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Nope, I filled mine summer of 2012 and it still has some 2012 water in it. I've never drained any water from my pool.
    38,290
    I will probably have to replace my water every 4 years or so just because the CH rises up to 150ppm per year just due to evaporation.
